ive been waiting on swaybars from the US for ages....
suppose thats what happens when you have them shipped and only pay $165 for a front and rear :P
sheeeet dude that's cheap! I got whiteline for 180 each..
good old sydneykid group buy...
overcharging for 1 part by $200+ over retail for years in his super discounted group buy
Bought the same parts at my local repco (and no I don't know anyone there, and never bargained with them) and saved at least $500 over what SK was charging
I now want to hit the ex across the head with a shovel.. Gets engaged and then calls my sister complaining about how tight the other dudes being.... Why call my sister for? Of all people.....
Didn't he just f**k off with people's money for ages too?
cos she has bigger nuts that you
R33 GTR seats don't hold you in for shit. I'm getting a bride when I get all my suspension goodies
That's cause you're a runt :D
They hold my tubby ass perfectly! But then i have the seat upright so gravity works!
no idea, I was long gone before that ever happened
What clutch are you getting? used to be able to get a nismo clutch kit including lightened flywheel for like $1200 brand new from nengun
Farkk.. It's costing me $950 for my new clutch kit. Then another $500 for a lightened flywheel. I can see this trip to the mechanics going well over $3000
why are you going a lightened flywheel?
they get the revs up faster, but they also drop faster in between gears as a result.
what are you intending on using the car for?
My mechanic was insistent that it would work better with the clutch I'm getting. So I just told him to go for it.
I was going to get one anyway. Less drivetrain loss :)
Car is predominantly a daily, but used for hill climbs and track days too.
Trying to get a good balance between looks, performance and practicality/reliability.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
