Haha good call. He's actually not making money off the clutch. That's the price that his wholesaler gave him. It's a bloody good clutch though. Definitely overkill for what I need but meh :P
Was that for 3S-GTE? And was it a whole kit? Or just the clutch itself?
http://www.eziautoparts.com.au/heavy-duty-cushion-button-clutch-kit-tyk-6441hdcb.html
Exedy website gave me that part number for 3s-gte. Dunno why you don't just get a hd or even an OEM replacement for a fraction of the cost
Put stock airbox back on today to see if i noticed any difference to pods, seems about the same maybe a little slower but that could just be the filter - much quieter though no more SSSSSSSSSSSSSSSSSSSHTUTU.
Still got same boost problem though, even though i did fix a suspect clamp that had sort of fallen down out of position
Leigh, imma tell you what these guys should have told you a few pages back.
If you don't know what it is or what you're doing...take it to your damn mechanic already!
