I didn't mind you looking at the car. I was in a hurry as you could tell. One word answers maybe but I wasnt unhappy with the crowd.
Ahh yeh I kinda figured you were probably in a hurry, applogies for the calling of a dick then ;)
need an answer to this quick:
Took my car to Beaurepairs to get my front wheels balanced! they finished and when I went out the guy tells me that one of my $250 kics nuts has been threaded and same as the stud on the spacer. Is there anything I can do? He told me they were hard to get off so he had to get them off by hand and it was f**ked already....
http://www.tradingpo...t=true&AdOnTop=
price seems reasonable?
Think that's alexs car. It's awesome :)
Alex sold it to Cooter.
I believe now it has a 2.8lt and a decent pair of turbos.
I drove it with -5's from memory.
yeah, but the things i'd do to that chick.
Giggidy Giggidy!
sounds like they farked it and are putting it on you, proving it is the hard part.
beaurepairs are fags why'd u go there
I'm not exactly sure what nuts you've got on there, but I'm guessing they'd be some kind of lightweight nut like the rays ones....Sounds like they used the gun on it when you're only supposed to tighten/undo em by hand...
I can get adjustable cam gears put on during my 100k service and drive around with no dramas yeh? Like dont need a tune or anything?
Set them to 0, should be the same at stock ones then
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
