My European adventure firesale is turning into a great success.
Laptop is now sold. So, who wants to buy a Navman? MY55T. Bought last year for $330ish. Will sell for $130. Yes, that's right people save yourself approx $200.
Works perfectly, comes with cigarette lighter charged and usb charger.
