makes sense. my mechanic did EVERYTHING on the car for me. ordered and fitted parts, flushed and changed all fluids, filters and spark plugs. made sure everything is working the way its meant to. im happy with paying that much for a job well done.
why pay someone to do something you can easily do yourself at home :thumbsup:
i do oils, plugs and filter every 5-7Ks anyway. brake pads take me 20mins to change over
if i had the right tools i woulda done eveything else myself.
but hey if you dont mind paying nothing wrong with that :cheers:
lol think u could take on clutch, transfer case, brake, power steering, gear box and front and rear diff fluids, flushed and replenished rimon?
sounds like a headache to me. better that those who are qualified do it :P
Thanks for the stories :) sounds about right then! Not sure who I talked to at racepace but a nice bloke as well
And yeah, I basically do my plugs / engine oil and basic stuff but rest CBF.
if you provide a hoist it shouldn't be a problem, surely you know how to use a spanner..? :P
I live in apartments.
The amount of space i have to work in, is basically the size of a GTR. It just fits in the carpark dimensions as it is.
So clearly not going to happen.
The labour for all of mine was around $300 - so the fact it would have literally taken me ALL day to do it in such a confined space, that's just how it goes for me.
I've done my own services in the past etc, but sometimes it's just not feasible as time is money.
usual rate is about $25 an hour, so he spent 3 full days working on your car?
What crack have you been smoking? The going rate for labour is normally $80+ per hour, they probably pay their workers less than $25 per hour but I don't know any stupid enough to charge so little.
When are we playing again Kris? :P I came pretty close to beating you last time. I'll admit you've got serious skills though.
I will whenever you wish to die next haha. Tonight?
Get it dezz. It's a bit different but when you sus it out you will love it
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 🥲 But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
