i dont know how this works.
but i'm going fishing tonight.. anybody join me? 1am @ kerferd rd pier.
would be down but i have work tomorrow :/
btw, im gona go preston markets tomorrow, get some fresh garfish and whiting for bait.. also rigged up a heavy rig for the big ones out there.. one of the boys had his whole set up snapped from a bite...
didnt you sell your car already? like twice or something?
lol this plasterer showed up at work today in his vx hsv with straight pipes, one of the meanest things i've ever heard.
Deal fell thru
I would get an 8 for the pure reason of not needing a tanker following you to fill the zipo lighter near the boot.
you do realise that they are all the same shit when it comes to having small tanks
i think the 8 is like 52, the 7 is like 48.... 4 litres isn't really going to give you that much extra distance when most are using on average 12L per 100k
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
