i've only been once in year 12. kunt started throwing punches like a mofo got me twice in the face/cheeks but were piss weak just gave him a nice blow in the ribs and he fell down struggling to breath lol ambulance had to be called over
say no to violence :thumbsup: most times...
last 3 weeks of yr 12 and the 10s came up for no reason and ganged up on my friend
we were trying to break it up when one little runt punched me in the neck so i grabbed him and tossed him over the fence lmfao
I got mine when I was like 14, just jumped on a trolley on its side and it bends and pops out.
Just watched wrestling on One funny shit. can you smell what the rock is cooking? gotta love him bahaha
you remind me of Nelson from the Simpsons fkn bully picking on year 7's :laugh:
kickboxing is where its at if you wanna learn how to crack heads in style and have fun at the same time :thumbsup:
after a few classes you'll feel like taking on the UFC lol
should get back into it
im doing the same thing in July :cheers:
mainly looking forward to spain, italy and germany
spain - wanna visit some stadiums/football clubs
italy - visit heaps of places but mainly ferrari related and also some football clubs
germany - do a few laps around the nurburgring in a relative's E60 M5 :D
should be fun
That's awesome dude. Will you be in Oktoberfest? If so we should have a stein or two.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
