why do you need to go over 180km/h?
You will most likely fark up your hicas and sensitive steering if you chop the speed signal wire from the ecu. (basing this off r32)
You reach 180 at Calder about 3/4 of the way down the Straight. The guy in the white 34 with gold bbs wheels (sorry dunno your name) was driving down the straight sitting on limiter lol and as for hicas, that's long gone, I have a lockbar.
cops got nothing better to do they may as well stick exhausts up there asses, my 4" cannon wont satisfy them I recon.
Billy how did you go any pics?
I've got stock ecu and looks like still has all the standard nissan wrapping and tape stuff as well and I can still get over 180 :D
Driving V8s at sandown tomorow :D
Me too.. Was so pumped for clubbing tonight. Got all the way to the city then my mate's car overheated. We got it going again but the mood was dead so just came home again at about 1.30 :( Epic fail of a night.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
