why do you need to go over 180km/h?
You will most likely fark up your hicas and sensitive steering if you chop the speed signal wire from the ecu. (basing this off r32)
You reach 180 at Calder about 3/4 of the way down the Straight. The guy in the white 34 with gold bbs wheels (sorry dunno your name) was driving down the straight sitting on limiter lol and as for hicas, that's long gone, I have a lockbar.
cops got nothing better to do they may as well stick exhausts up there asses, my 4" cannon wont satisfy them I recon.
Billy how did you go any pics?
I've got stock ecu and looks like still has all the standard nissan wrapping and tape stuff as well and I can still get over 180 :D
Driving V8s at sandown tomorow :D
Me too.. Was so pumped for clubbing tonight. Got all the way to the city then my mate's car overheated. We got it going again but the mood was dead so just came home again at about 1.30 :( Epic fail of a night.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
