I thought he got it for ~4k
this. He's trying to make around 1k more than he spent.
On another note i'm pretty sure that the police are stalking me... Can't even get away from them on the train home!
Only do it if your wheels poke past your stock guards and you want to get a flush look.
Of course.
It's just cos there's a set of Meister in crazy size and dish up for grabs and there's hardly any widebody kit for R33's.
Nothing concrete now I'm in my usual mode of don't know what I want.
They are china spec carbon I think, I saw there pics in the FS section.
They surprisingly do look good.
No one came across one that bolts on like 240Z's etc?
Of course.
Cuz R33's are wide already :laugh:
Give us a look at the wheels.
+1 or else they just look tacky.
On another note, my brother is after coilovers for his 33 GTST - wheres a decent place to get some decent ones at a decent price?
Import Monster, speak to Aaron.
