soo took car out need help asap.
full acceleration sputters at about 4.5k in second etc why would this be? serviced last Friday thinking coil packs? need help got Winton Sunday so times a tickin
kgo
thanks in advance.
kgo
thanks in advance.
Coilpacks or dodgy afm. My bet is on coilpacks
Alex, start the motor then unplug the coilpack one by one, if the idle haven't changed then it's faulty
By idle change, I mean a working coilpack should make idle rough if you unplug it.
last worked yesterday, gave it a high pressure hose but not in the engine or anything .. oh had sway bars installed last night cant see that having an impact.
perhaps water got in/on them but super super unlikely
and like i said was serviced on friday last weeek so 'should' be all good..
That's only if you have a completely dead coilpack to find out which one is dead. Not when they miss at higher revs.
Would offer you stock coilpacks alex but mine are series 2 ones
i've got some stock series 1 coils here al if you wanna mix and match our 2 sets you are welcome to them
Hmmm Sau Vic membership is up. Dunno of I'm going to renew. I hear a lot if people are contemplating not renewing ;)
BUT I wanna do deca hmmmm LOL
of course you wanna renew.... for 3 years... at the dyno day!
thanks man :thumbsup:
should be ok i got 2 full days to find aftermarket or worst case a 'new' stock set if thats what i need guna take the car out in the morning just to see if problem is still there or if it was just i dunno water got on someting it should have just never know with 16 year old cars that get thrashed haha :whistling:
If you just had your plugs changed, there's a chance one of the plugs is loose...happened to me once, back when I first got my car...was driving to heathcote, gave it some boost and it started to sound like a rexy....thought it was all over, limped to heathcote, poked around in the engine bay while waiting in line to pay entry and found the loose plug...big relief lol
yeah thats true just cop the negative feedback
but just start the fricken auction at the minimum price youd take ffs
Or start low, spark a potential bidding war, and always have the option to not sell if you don't get your price.
anyone found me an abu-esque 32 yet?
haha old school. Not hard to pull off. Type-M sideskirts/pods with r32 gtr frontbar and some crazy fitment. This was before Hamish strolled in with his fitment bizness :nyaanyaa:
Sinnister's r32 is epic win
this one is nice too, but epic low.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
