U trying to be one of the big boys now mohsen? The difference between u trying to get a 17 year old and say... Jeremy, Adam or hamish is monumental. Cuz ur still a kid too. They're not. :P
i am a big boy
stop hatin hater
Lol Mohsen, you're the same age as Alex (GTEES). He hits on the same girls as the rest of our crew (18 - 24).
18+ = a big boy in my books.
vag is vag, tits are tits
try having a grandma come onto you.....
myself aside, pls try to be a decent human being next time. Might make u more appealing to the women born in the same decade as u
also.. That is the difference Adam. It doesn't sicken people when someone mohsens age sees someone a couple years younger...
lol, and you'd define a decent human being how? As far as I'm concerned I've done nothing illegal, nor have I hurt anyone in any way...so I'm confused how I'm supposed to have hurt...you? Again, it's not a problem with getting girls my age or older, because this is just as much a norm for me as younger girls...and I don't *target* young girls...which is what I think you mistake me for doing when people like you wrongly term me a "pedophile". I'm just open minded to the type of girls I'm willing to be with. Therefore I'm not going to knock back a younger, legal girl, that I find attractive and who finds me attractive, based on me being concerned with what other people, who probably haven't had sex for a very long time, might be thinking of me. You miss out on a lot of good things in life if you concern yourself too much with what others think of what you enjoy doing.
Haha you did make a quick escape tho birdsey when you found out shani was 16 haha
LOL that girl lied about her age to me anyway...again, I don't target them :)
And quick escape was for other reasons that you already know about :P
And this proves what? That I was as happy to be with the girl when I thought she was 21, as I was when I found out she was actually 16? I don't care about the age. As long as it's legal, and I find them attractive and vice versa...could care less. The only thing that was a deterrant was being lied to...
little little kids have bits too before you go saying thing like that moh. Wheres the line?
Being realistic here, not like I would go for a 12 year old. That said youngest I go is 16 now.
The line has already been pointed out, and it's 16.
Not sure what gives you the right to call any of us "pedophiles" when we're not breaking any laws AND it's all 100% consensual?
Nope, I'm castrating myself as we speak!
f**k that hurts.
That's why you call yourself Citizen Snips.
You would not have checked her ID anyway.
:laugh:
LOL good call.
Well yeah, it's not the most romantic of things to ask for some ID mid kiss, nor do I have a scanner built into the dash of my R33...but it's getting pretty sad now, that we pretty much have to do that or risk going to jail...
This. Far be it from me to second guess the Legislature. Lobby your local MP if you disagree.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
