Getting an ultrasound guided injection on Wednesday, other than that it's getting better :) haha
is that the bullshit they do to inject the f**ken dye before an mri?
if its that, i cried when they did it to me.
Nah, its not that bad. lol.
Edited by xALmoN
You're joking yeah? You're not actually considering that as an actual option are you?
Don't mean to offend you, but it's a 33 GTS-T, it's not something rare. Why the f**k would you even consider having ~$10k sitting there for a few years to one day, maybe, turn it into a track car when you come back...
But I'm sure you were just joking, because any half wit would understand that parking $10k in a garage for 3 years to maybe turn it into a track car is the most ludicrous thought one could have. That same half wit would know that $10k in your bank account when heading overseas is far more beneficial than a $10k garage ornament that will be worth $3k when you get back to turn it into a track car, losing ~$7k worth of potential track mods in the process.
Tough decision though..
You went a bit over the top there don't you think bloke?
The car might not be particularly special to anyone else, but it is to me. That's all.
I'm trying so hard to get a taste for it, but I just can't lol. I think it's an 'aquired taste?
I don't really have a taste for them either. Also depends on which red wines you been trying. Some are great and some I think are shit. Best ones to try would be the soft reds such as a merlot or Shiraz that aren't too dry.
I concur with Dezz on this...
Put the 10k into an account mate.
Lock it up for 3 years - same as you would with a car.
Come home and pay off some of the epic debt you'll accrue whilst overseas, or come back and really build a proper track car.
Whilst a car is special to one and so on, end of the day sometimes you just have to make the decision to cut it away.
I've been having sleepless nights lately over the GTR and keeping or selling & buying a place with my brother. It'll be 3-4 years longer if i keep the car simply because I cant have a 360rwkw GTR sitting there and not take it to the track. Then if i bust a motor etc... fk...
Only problem is selling will effectively castrate me having to drive around in a mid 90's commo or ford. Cheap and stuff but just depressing.
Decisions decisions... What life is all about. The tough ones are hard for a reason but once made, in the long run its better for you.
I don't think I went over the top at all...At the end of the day it's a car, and unless you've spent a shit load of money customizing it etc, chances are you'll be able to pick up a 33 gts-t for about $3-4k when you come back, and make it just as 'special' is.
Cheers fellas, Selling it is definitely the right thing to do. Sigh.
the upside is that you can potentially do it all over again and avoid any mistakes you made the first time...
like buying an R33.
I was actually at a high school yesterday with a massive group of girls wanting my autograph and photos with me... :P Gotta love being a muso.
But no, I didn't do anything.. Otherwise I probably would have been locked up haha
Edited by jezza boii
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
