what do people think of the new fords supercharged v8? i love it and it sounds so good too.
Everything is good except the fact they are Fk ugly a. Interior is cheap and basic steering wheel looks like it belongs on a Volvo bus
Hsv all the way
Man imagine of Shan wasn't an admin. Kent would be banned from 4chan
LOL!
<3 Jamies pics
I do make a R33 look good, in a photo :laugh:
you've been smoking too much pole if you think a 32 or 33 looks better than a poopra. They may be lighter and easier to steer, but they sure as shit don't look better.
I thought you hated Supras?
this shits all over holdens v8, none of theres sound anywhere near as good as this:
http://www.youtube.com/watch?v=lDAChIpBsY4
My uncle has a R8 wagon i think with an exhaust...
Doesn't have a blower whine like that but the exhaust note was quite a surprise, needs to be a decent system though. Not just some straight through pipes and crap, they just sound raspy.
Mate of mines blown LS1, sounds like a banshee coming up behind you. <3 blowers
im sure that LS1 would sound crazy. its the only way to make a holden v8 sound decent is with a good quality exhaust or else they are just so quiet and dont sound very good. but this ford with a stock exhaust sounds really good.
dream on scotty!
i realise this isn't exactly a stock exhaust but meh! has to be my favourite exhaust note hands down
Ye that's what the R8 wagon my uncle's sounds like, brilliant exhaust note.
Just exhaust and a tune i think it made 240rwkw. Not bad for a work wagon lol.
yeah that hsv sounds good but it isnt stock exhaust though, what i was saying that ford with the stock exhaust sounds better than any hsv with a stock exhaust i have heard. and im sure when someone gets a aftermarket exhaust for this new ford it will sound even better.
and that LS1 sounds awesome i love the sound of a supercharger with the deep note of a v8.
Oh and Alex - things are now even from that previous thread.
Didn't see the last line of comment. What is good for the goose is good for the gander in my world :)
still dont see how they are 'even' and still dont see how i wasted the mods time.
but whatever still got 40% to go should get me by :rofl2:
