May have filtered some of my words and made it unreadable... either way, mohsen is not one to offer advice on buying cars lol
And your not the one to give advice on cosmetic modifications.
We make a great team lol
stop posting cars just like yours but with balls....... and DO IT!
http://www.skylinesaustralia.com/forums/topic/359280-r32-gts4-4-door-manual/
u mad mo?
so BN skirts and fibreglass GTR bumpers are what you aspire to?
Do-Luck sideskirts :P Just a pic, nothing to aspire to.
plus im rockin my std front bar, so no gtr bar for me. Need to find that front lip though which is no more on yahoo auctions :(
Was on my way to check out some furniture in a house my friend is selling for some rich motherf**king international exchange student...
Speaking of which.
I keep seeing a white Lambo out the front of my work, Asian student gets out each time and goes into the student accomodation block across the road... lol.
I see AMGs and all sorts of other thumping cars and sometimes with P plates on them
It's seriously taking the piss @ reality.
start new role tomoz
bring on 10gig ethernet, mega networks
spanning tree
and cool shit :D
so cant wait
im pshyched
Nice what company?
Windows environment or something else?
And Mohsen as if get a commonwhore after driving a couple of them its like >_< Not to mention you drift them around a pole and your power steering will die.. :D (a mate of mine did this, and by drift I mean single spinner of DOOM!)
Speaking of which.
somethingliekthis? redpplater
Speaking of which.
Friend told me this guy had a brand new BMW X6, now has a Z4...
How do you know those guys have had those cars paid for by their parents? For all we know the guy could be an astrophysics whizz who's banging some hot Asian beaver from the student accom block.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
