here's mine, not one being deserved lol....
Blitz Note Added 06 October 2009 - 01:28 PM
Added to warn level Failure to follow forum rules - Comments made in sale thread:
Quote
i would rather gouge my eyes out and then blindly stab at them with a rusty fork...
PranK Note Added 01 June 2009 - 10:08 AM
Added to warn level Sexist comments made in thread - http://www.skylinesa...0786.html&st=20
dan_the_man Note Added 04 November 2008 - 04:15 PM
Added to warn level Defamatory remarks made towards businesses or individuals will not be tolerated on this website
1, the dude was selling phat pants... PHAT PANTS...
2, suggested to a female member that naked pic's would help with her topic (as was the style at the time)
3, mentioned that nengun is slow, and that their advertisement to buy into thier business of "excellent customer service" was lulz worthy
Told some cock sucker that his lancer does not beat vn ss's etc.
The warnings were still coming as you can see by the email notification in the bottom corner.
Got a year holiday after the 19 or so warnings, which woulda put me at about 200% lol
this guy lives in point cook and jess is his agent...
I see, yeah, don't know the guy.
But Jess, I do :)
Hope she is a good agent...
Tossing up dyno day but kinda cbf driving that far
Lazy kent :laugh: It's not that far.
wtf is this, surely I'm not the only one that thinks this looks stupid.. sure the rims are nice but thats about it and ruined by stupid camber anyway.
It is a Nissan S13 Silvia with Honda Odyssey head lights, called the "Odyvia".
Runs a L28 with triple Nismo Solex 44 HH carburetors.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
