lol i'm not surprised... :/
i work IN a pho joint now man, so i make my own ;)
seriously man, we dont need to hear about every chick you bone or think you are going to bone...
we've all had sex before (except mohsen)
any good, will have to try one day
where abouts is it?
Day 5 of operation 'anti fat-bastard'.
i lost like 5kgs from my trip, thought id stack on the weight drinking/eating and doing nothing but was the opposite lol
Not so far, should have asked him how long they have been in there for. Why do you always think of things like this afterwards...........?!?!?!?!
no idea man, my exhaust tip was able to melt some parts of my rear bumper, so i reckon they get pretty hot.. the hangers though. are a different matter.
where abouts is it?
LOL you make it far too easy Nick
Alex how do you reckon the warandyte to kinglake area will go in a few years? Currently saving for a deposit to buy in a few yrs
Dude, have you seen the houses in Warrandyte?
They are huge + the acres of land that some ppl have for their back yards.
Houses start from $440,000 to $1.1+ Million.
Ohk thanks al
Yes I have Jamie, 700k gets you a nice house with some big land. I inherit my parents house and since the oldmans retiring soon I'm thinking about going somewhere quiet for them and renting out the LALOR house and sooner or later I'll be laughing as land prices shoot up like mad
Ohk thanks al
I see,
So you and your parents wanna move out to Warrandyte?
yup, nice big land, big shed, and nice drive there and back, especially in a skyline :thumbsup: and not far from apple peal lol
my uncle just picked up a house in lalor for about 480k, and thats cheap compared to others. so with the inner city fringe expanding and shit prices are only going to go up n shit.
amirightalex?
and this is why im living like a peasant...
Edited by Mohsen
Kinglake has decreased on prices ever since the fires. You can pick up a decent sized block for less than 100k. Only downfall is that often the topography of the block is often undulating, I.e higher construction costs because of the need for cut / fill etc.
My mate had a motorcross track in his backyard...and a big f**k off digger thing to build the jumps/table tops etc...
Snapped the frame of my Pee Wee 50 there one day, welded it up and sold it for $600 (my mum bought it brand new for my brother for about $200 18 years prior)
make it stop
where abouts is it?
review
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
