yup. miss that thing already :unsure:
on that note, was talking to a chick on teh cellular phone. my mates getting sus, im like, lols tims getting sus about this
her: oh whut does he think im your mrs?
me: yer
her: oh lollzz i probably will be mohsen, dont you think
me: probably not
her: ohh...
motherf**ker. she barred me on saturday for that >_<
Nah the laws of hard ball will always apply IMO, the only thing that changes is the words/language you use. He's doing it the right way...not telling them to f**k off, but suggesting they put more on the table because he's not quite enticed yet.
1968 was treat em green (weed) keep em keen.
This. Keeping in mind the phonecall one was supposed to be my +1 to the movies n shit. You know, I know she wants meh, she knows i want her, but just gotta let her know Shes going too quick.
Also, valentines day. Told her I'll pick her up from school and well go somewhere. Never even left home. She waited for ages.
And still all lovey dovey to me. *insert troll face*
And I literally punched a bitch in the mouth once.
Even when you treat them well they tell you to get f**ked
Zactly. For some girls (read: many), knowing that you want them is sufficient for their ego. *insert big empty space here, where the need to sleep with you for validation used to be...soon to be replaced by the act of masturbation*. Of course it does require them to find you acceptably attractive in the first place...but even if they don't, you can still fill a girl with sweet insecurity and try your luck at that?
P.S. agree with Jez, Moh...unless she took a shot at your nuts, in which case, open season on her face...don't be hittin them :domokun:
*insert big empty space here, where the need to sleep with you for validation used to be*.
On a side note to this..
My mum gave me a massive lecture the other night about sleeping with girls that I'm not dating. I tried to explain the concept of casual sex to her but she is absolutely insistent that the girls are doing it only to impress me, and that they're looking for a relationship.
Do you think this could be the case? The girls tell me they're dtf, but I guess women are always hard to read.
did everyone else miss that?
Depends on the girl and the situation / what is said between the parties. Some girls use it as a trap to try and get a relationship out of you (in the same way that a guy will use a relationship to get sex out of a girl)...some are genuinely after just a good time...
...some misread you totally, thinking that you proposed to them that night and have every intention of spending the rest of your life with them:
Huh? I just wanted to post the forever alone guy :mellow: But i do agree, "treat 'em mean" still has some merit
No. Mohsen is 18, it's ok for him to be preyin' on school bitches. Let's not discuss that old chestnut again!
Birds, I think you're right about that relationship trap. So many girls have tried that on me, and I never took a bar of it.
I think it's male-nature to lead them on a bit if they're playing that game, but I force myself not to do that. It's not worth all the bullshit involved.
Edited by jezza boii
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
