Lol eventually she will realise she can easily do better. That is when you'll get the "get f**ked" reply.
Yer that can certainly happen. To use a cliched analogy...it's like fishing...all about giving enough push to maintain interest and enough pull to maintain hope. If you don't bed her sooner or later, she will get sick of you though.
not really its just when you mention school seems so wrong, you'll understand as you get older.
I think I'm older than you and I still don't understand lol :turned:
physical age doesnt always translate to mental age
Exactly. Because it works both ways, you know. And this is where I think you rob younger people of their credit to make decisions for themselves, e.g. when it comes to consensual intercourse. I'm open minded enough to listen to someone younger than me without feeling like my extra time on Earth will always rule over theirs. If they can present to me good points or a well thought out, mature sounding argument, I'll listen to what they have to say. Some of the most intelligent conversations I've had have been with people many years younger than myself. Then there are the dumb ass women in their late 20s who act like a 10 year old when you have an argument with them...so who is really of higher mental age? When I was 21 I dated a 16 year old girl who was a lot more intelligent than most of my female friends, as is one of the reasons I dated her in the first place. Yes, not all 16 year olds are going to be like that, but I certainly wasn't going to knock back opportunity for what could have been a good relationship with someone I found physically and mentally attractive.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
