:rofl2:
Yeah after running a 12.6 basically stock as a rock I'm sure my bro is kicking himself for putting money into his GTST
But meh, thats just drags circuit is fun as well :D
[/inb4 flame]
Also Scott what about a 370z?
they are way to expensive they cost more than a E46 m3 way to much for a nissan in my opinion.
organising inspections/test drives on these for next week.
http://www.carsales.com.au/all-cars/dealer/details.aspx?Cr=11&R=10243687&keywords=&trecs=35&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294931739%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=0&R=9205456&keywords=&trecs=12&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294922300%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=12&R=9950012&keywords=&trecs=17&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294848651%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?__Qpb=true&R=10337452&keywords=&trecs=12&__sid=12F5A5EA2F87&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__No=0&__Nne=15&Cr=3&seot=1&__N=1216%201246%201247%201252%201282%204294967194%204294967179%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=4&R=10285615&keywords=&trecs=12&__sid=12F5A5EA2F87&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__Qpb=true&tsrc=allcarhome&__Nne=15&seot=1&__N=1216%201246%201247%201252%201282%204294967194%204294967179%20903&silo=1011
Hey Kris, got the 31 back today. New turbo spools @ just under 4k rpm, the lag is not as bad as I thought. Pulls pretty damned hard from my short restricted experience today. Only tuned to 240rwkw, coz the clutch slips with any more. Didnt get a new clutch at the moment (only had the other one just over a year, havent punished it badly either) as I also need to get 25 gearbox & sort out something with tailshaft. The extra power makes the condition of these so much more obvious. I'm happy with it at the moment. If the lag gets to be too much of an issue, I'll put a smaller one in and save this for a dohc motor.
Can't seem to get a broken bolt out of turbo :/ mechanic's tried drilling it etc still won't budge.
He said he has tried the front pipe (jjr bellmouth) on with 5 of the 6 bolts done up and there is definatly no leak, is it okay to leave it like this? I have plans to hi-flow it through hyperflow soon, hoping they will be able to do something about it - will this be okay for a little while?
*insert scared face*
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
