at the end of the day, my beat up cars look beat up cos I beat them up.
your car looks like a bag of dicks cos you love yourself a good bag of dicks?
:P
come at me bro.
Come at you? Sif I wanna get in trouble for smacking a 5yo boy :P
Unfortunately I didn't do anything. Took her for a long freeway drive before work this morning. She spluttered a few times yesterday, like I said I think it was old fuel, and lack of it. I filled the tank & went home, spluttered once. Thought I would leave it for petrol to settle & take for a good run this morning. After not missing a beat all run, exiting ring road @ edgars to go to work, bloody thing wouldn't down gear & couldn't feel friction point of clutch engaging. So sat @ light pole pos & pissed alot of ignorant pricks off, who could not see that I had my hazards on (checked and both indicators working, ppl just fkn blind), until getting towed back home. I guess 1 year old (hardly abused, in v.good condition) exedy hd clutches can't handle 240rwkw
Went to the Museum today, parked next to a R35 GTR. Walk around the corner and there is another R35 GTR. Both were that Titanium colour, so sexy mmmm
I have met those guys, they are brothers. they both got those 35's within a month of the release... nice dudes
usually they park them one behind the other
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
