What model would you be looking for though?
wtf are you talking about?
$10k wont get u an evo 6 and the auto GTA's were only released in the evo 7's and came out in 2001, and even those u wont get for $10k
id look at an evo 8 or 9.
TRD = TuRD
haha I actually made the website for TRD and some other branches of Toyota a few years ago, so when I was having specification meetings with their managers I kept calling it Turd for lulz. Eventually one of em took the bait and lashed out. Was good fun. They let me "test drive" their TRD Aurion and Hilux. TRD Hilux is instant pants party time, but they didn't like it when I told em my old man's 18 year old stock ceffy was faster, roomier and better equipped than their Aurion masterpiece. On the way back from the test drive I hopped in the ceffy and the mechanic in the aurion, and for shits n giggles I gave it a squirt and beat him by a car length. Oddly they never brought it up again.
I agree...Don't know if your car is just that quiet, but the 'action' shots were pretty boring due to hearing nothing but road noise...Seems like a fair bit of work was put into making a professional video, but most of what people would watch a video like that for was non existent...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
