i just use 3.5mm to 3.5mm cable from ipod/iphone into sony headunit which came in my car.. put ipod/iphone in the drink holder :P
id like something a bit better also - blue-tooth seems pretty cool considering wireless hands free.. instead of some stupid phone holder
but i id rather buy decent car parts than audio stuff really >,<
Bob dylan could never sing for shit, but all the hippies were too stoned to care..But by the time they realized it, they had somehow made him cool
I got bored of xd9s, became to common for me... The enkei's aren't too much bigger that what the xd9s were.
Sporty enough?
Ok I take it back.... :yes:
Got an am/fm radio in my car :cool:
And a radio transmitter thing to plug into my iPhone for some scratchy quality tunes through 107.9
Boom
And sways are probably one of the best value suspension mods, especially on a 33. When I get home from work I'll try dig up the super body roll photos of my car at drift for dummies when it had the stock sways in
bluetooth integration bitches
That would be convenient. With using for phones I don't think my iPhone 1 has ever worked it's bluetooth properly.
In the Skyline I had an FM transmitter for $40 from JB that worked perfectly with my iPhone, now I just have a direct Aux cable in the ute. That one could have been designed a little better for handling but does the job.
$40 for an FM transmitter?
Got mine for $7 off eBay...
They're hit and miss, I've had things fall apart off eBay defeating the purpose entirely. I was happy to pay for known quality, my music is important.
why bother with an FM transmitter, just tune the radio to some community station that will cut in and out and give you 30% static over all your music and cut out the middle man...
I shaved my aerial coz I never listened to the radio. Now I want to listen to the radio, lol fail. Gonna get me one of those receiver strips that goes on the back window or something.
My $7 one works perfectly and charges my phone at he same time. So did the 2 my mate bought. Only reason it's sometimes scratchy (very minimal) is coz of my coat hanger aerial.
My mare paid $50 for an AUX cable and it doesn't even charge his phone
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
