i just use 3.5mm to 3.5mm cable from ipod/iphone into sony headunit which came in my car.. put ipod/iphone in the drink holder :P
id like something a bit better also - blue-tooth seems pretty cool considering wireless hands free.. instead of some stupid phone holder
but i id rather buy decent car parts than audio stuff really >,<
Bob dylan could never sing for shit, but all the hippies were too stoned to care..But by the time they realized it, they had somehow made him cool
I got bored of xd9s, became to common for me... The enkei's aren't too much bigger that what the xd9s were.
Sporty enough?
Ok I take it back.... :yes:
Got an am/fm radio in my car :cool:
And a radio transmitter thing to plug into my iPhone for some scratchy quality tunes through 107.9
Boom
And sways are probably one of the best value suspension mods, especially on a 33. When I get home from work I'll try dig up the super body roll photos of my car at drift for dummies when it had the stock sways in
bluetooth integration bitches
That would be convenient. With using for phones I don't think my iPhone 1 has ever worked it's bluetooth properly.
In the Skyline I had an FM transmitter for $40 from JB that worked perfectly with my iPhone, now I just have a direct Aux cable in the ute. That one could have been designed a little better for handling but does the job.
$40 for an FM transmitter?
Got mine for $7 off eBay...
They're hit and miss, I've had things fall apart off eBay defeating the purpose entirely. I was happy to pay for known quality, my music is important.
why bother with an FM transmitter, just tune the radio to some community station that will cut in and out and give you 30% static over all your music and cut out the middle man...
I shaved my aerial coz I never listened to the radio. Now I want to listen to the radio, lol fail. Gonna get me one of those receiver strips that goes on the back window or something.
My $7 one works perfectly and charges my phone at he same time. So did the 2 my mate bought. Only reason it's sometimes scratchy (very minimal) is coz of my coat hanger aerial.
My mare paid $50 for an AUX cable and it doesn't even charge his phone
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
