FnF5 was pretty good. one or two anti-ricer quotes from the Rock shows they're over the ricer spec look from the previous movies and also alot more action, nice.
i think i may have fallen in love with an american car :/
oh and that biker chick aswell...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
