Getting
-5's Garret
Tomie Dumps
Blitz front pipe connected to existing 3inch Nismo CAT
Custom Exhaust Back 3inch to twin pipe tip
Boost contoller
Adjustable Cam gears
Get 3.5" exhaust from the cat.
Your looking at about 350-370 rwkw from what I have read - depending on boost / tune etc.
Some people get cams, not necessary but may be something to think of when doing it all at once.
Happy with 300 at the moment. Got to get used to it :thumbsup:
When engine needs rebuild then re-tune for 400 with fuel pump etc.
You will get use to it very quickly, thats whats funny about GTRs because of the 4 wheel drive it will grip and just go, whereas if you have 300rwkw on a RWD car on street tyres and go to say 400rwkw.. it wont feel that much quicker simply just spin the wheels more than it did before :P
Be careful though, moreso in the wet - GTRs can still get VERY sideways.
Do the 33 Moh...much more reliable and an all round better built car. When you drive both side by side you'll see that. It's like when I drove a 34 after driving my 33...the difference in build is quite noticeable. Newer cars are almost always better in terms of an overall package.
As for looks...well yeah that's totally subjective, but there's a reason R33 are so common...whether the R32 fanbois like to admit it or not, they are received as a good looking car. I get the feeling a lot of people hate them purely because they are so common.
The R32 may LOOK better to some, as this is very subjective but no denying the R33 is the better car. And the 32 Interior is aids duno anyone who prefers it over R33 interior.
Excited to get my car back tonight after tune (status).. base dyno run was 238rwkw so only 5 off the racepace dyno so pretty much spot on when you take into account temp / baro preasure etc. I'll be happy to see anything over 260rwkw anything over would be a bonus for me, hopefully a lot more power early in the rev range as well.
only 32grts look better.
I WAS going to get a 32 GTR.. but realized whats the point for the same price you can get a car up to 9 years newer and like I said the interior is AIDS! Very hard to find a clean 32 these days as well.
Hmmm it isn't that serious Atm so something that isn't all like omfg I love you would be pretty nice.
don't get her anything? just leave the toilet seat down as a thank you the next morning.
Too laggy for a street car.
They are utterly useless below 150km/h, -9s are faster to 150 - I can promise you that.
You also notice the lag in/out of gears massively.
Its now a case of pushing really hard up through Kinglake etc as there is so much lag coming outta corners.
stock dumps will be ok as well.
i had stock R33 GTR dumps, made 340rwkw outta -9s on a full build.
spent $600 on tomei when i put on -5s... all that changed was the exhaust note.
power/result was the same as other -5 equipped cars with factory dumps.
need 3.5" exhaust @ a min though, and big front pipes
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
