LOL ok maybe not :P
my uncle's owned about 14 beemers so far never had any problems except for a e36 323i which did end up costing him thousands but that was a lemon to begin with.
obviously dealers are gonna screw you up if you want the service history but he's only asking about a cheap 5 series not a fkn M5 so who cares about documents you're gonna lose on resale with the skyline too...
yeah true alot more parts to break etc but they're not THAT expensive and wont break everyday. i'd be more worried about the big stuff engine gearbox etc which from what i've been told and read they do last.
its pointless asking here really if you wanna know about the car go read about it on BMW forums, test drive both then make up your own mind. you're obviously asking here coz you wanna be told to get the skyline..
not "that much more expensive" as if, anything euro costs fk loads more and is a way bigger headache than jap parts particularly something so common like a skyline.
yes there are alot of 5's but good luck if you stack it or need a part. it WILL cost a lot more.
What's the name of this app? I'd like to try it and see what sorta fkd up shit I come up with
Search for 'sleep talk' in app store. It's a little red icon with a silhouette of a white bed (if that helps),
I've been using it on and off all year. The shit that I've come out with is AMAZING lol.
got it :D
Alex, know anything about landlord insurance?
Quotes from RACV and AAMI are like $400, but terri scheer and Property insurance plus want $240-$280?
Whats with the difference in pricing? Is there some clause or something hidden??
Who do you (or your clients) use?
thnx
nigga preaze u trippin not like r34 xenon headlights are any cheaper...
in other news, been through just about every make/model on carsales and i've come to a conclusion - unless i've got 100K+ to spend there's f**k all on there that i really like.
thnx
My name's not Alex but I sell Landlord Insurance daily. Firstly, what do you actually want to be covered for? Premiums obviously rise as the cover becomes greater and could also be because the company may pay out more claims. So the cheaper quote would either only cover you for basics or they don't pay many claims and can afford to lower the premium. Good for premium, bad if you ever need to claim.
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
