Shame man. I couldn't even get to chapel. I was stranded in Brighton of all places. We should have another outing soon!
Friday night? My footy team has a bye this week :D
I havnt been going out lately... Need to save $$$
Altho we do have an odd movie night and everyone chips in for a slab and some food
Sometimes those kinda of nights are the best. We sometimes play xbox all night until 3-4am and just hang out. Seems pretty loserish, probably because it is, but still good fun. And cheap.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
