Shame man. I couldn't even get to chapel. I was stranded in Brighton of all places. We should have another outing soon!
Friday night? My footy team has a bye this week :D
I havnt been going out lately... Need to save $$$
Altho we do have an odd movie night and everyone chips in for a slab and some food
Sometimes those kinda of nights are the best. We sometimes play xbox all night until 3-4am and just hang out. Seems pretty loserish, probably because it is, but still good fun. And cheap.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
