http://cgi.ebay.com.au/Pioneer-FH-P6050UB-...=item5ad7ab3acc
what ppl reckon any good?
im not much of an audio person
just want to find a alright double din player cheap
Yea it's good. My bro has one in the r34
http://www.carsales.com.au/all-cars/privat...id=12867EF54007
f**kin wow :thumbsup:
edit: hmmmmm i wanna apply for an exemption for an R32 sedan but it says i need a vin etc.. what if i buy one and the application is rejected.
great idea vicroads
the application form says you have to apply for the exemption before purchasing the car - so you need a cooperative seller.
Still think a gtst will fall in the same category as a wrx or mazda 6 mps though
Computer shat itself last night... Anyone know how to recover data off an iMac? :thumbsup:
Time for a new computer me thinks. I only had the mac for home recording purpose (PCs don't run Logic 7/8/9). Will sell all my recording gear and buy a PC this time.
chuck G-Parted boot disk in the drive, plug a USB hard drive in, turn it on, when it boots into the UNIX recovery OS, launch file browser and copy your files to the USB drive.
Then move it to a new computer or try and resurrect your old one.
great idea vicroads
find someone with a GTS-t sedan on ebay, and use their VIN :P
Ive heard Isopropyl Alcohol is used to make drugs O_o
I buy Isopropyl in small quantities to clean surfaces prior to etching/spot welding/soldering and so on.
i said cheap fucktard :thumbsup: haha
I use one of these in the ceffy:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=320511759418
GPS and iPhone compatible, plus plays MP3's/AVI's off USB stick. Has input for reverse camera and all that shiz.
blags it was a city based operation targetting noisy cars..
gtr boy -got licence yet?
nope, turn 18 september first
find someone with a GTS-t sedan on ebay, and use their VIN :)
haha great idea :thumbsup:
nick i see you lurking
helpaaraboutman!
pm me ur vin :P
Edited by GTR-boy
Computer shat itself last night... Anyone know how to recover data off an iMac? :P
What you said... Buy a PC.
great idea vicroads
That is one of the worst R31's I have seen.
just get a non turbo car and be done with it..
u been going on about it for ever. its gonna be like the boy who cried wolf by the time u get something..
just man up and take the plunge but go non turbo save ursefl a pulsating rectum everytime u drive for the next 3 years
3 years? Err, I'm 21 :thumbsup:
UPDATE:
My mate has agreed to sell me his MR2 turbo for $9000 :P Provided he doesn't change his mind I should have it in about 2 weeks.
3rd Gen 3S-GTE motor (from 1995 model), lightly modded (upgraded SMIC, 15psi).
yeah had a look into them, just want something basic double din
already have a gps and thats the main thing i would use, no iphone or that
helpaaraboutman!
pm me ur vin :P
hmmm went bought some blank cd's
im upstairs and cbf going out to check it
UPDATE:
dont buy an mr2 unless its a GT
f**k having no power steering even if it is a MR engine config
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
