only interested to see what he has to say about his old 32...if the price goes any lower I might have to consider buying it...
f**k... for 7,800 i'd buy it in a second for a drift pig if i didn't have 2 cars already
for track work all it needs is straight pipes, better seat/harness and interior removal
do eeeet
would be nice to see such a great car/deal go to a vic member
didn't he have a 33 gtr? or am i thinking of someone completely different..
or maybe it was that silver 32 gtr that was sitting on its ass?
it is the silver 32 gtst that he had before the 33R
dezz from what i know the car is straight
^^ I thought Abu sold his R32 GTS-T a while back now..?
That's why he bought the R33 GTR, then sold that to buy a house...
RB Ryan has his Silver R32 GTS-T for sale - http://www.skylinesaustralia.com/forums/Vi...nu-t299103.html
do eeeet
I'm tempted... any idea why someone would remove power steering? weight saving is the only thing I could think of, but no idea how much weight would be saved...
my daily is a heap of shit though, so I can't buy a second car that might be a 'pig' in case I ever needed it for daily duties....
hmmmmm
saves weight and has a predictable feel and instant response for drifting :)
when properly setup its very light, I have a manual steering rack in my ksev and its almost as light as the power steering rack in the 33
haha i was in target, buying hoodies lol
haha yeah, looks worse becuase its lowered, car looks good though man.... forgot to check out the exhaust too
you think yours is dirty atm? haha should see mine, mud all flicked up on the side from the tyres from the new rims lol
i work on the other end of the store, mainly in the toy department.
the mud would definately show up badly on a yellow car, but it would just look like you have been out rallying :)
at the crown carpark lastnight i saw a ford BF model painted in midnight purple II.
Don't think I'd be doing much drifting in it... and wouldn't really want a car without power steering for street use, unless it felt like you say..
I'm even tempted by that gtst. Soo cheap, even cheaper without the 33GTRs on it.
How you finding shit-tec dezz?
If I wasn't at school and not working much I'd probably buy it straight away..
Not bad, first week was very slow, but this week was better, little bit more hands on...
Guest
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
