applying for a job as a train driver... yes you heard right... and they do random piss testing during the application process
dude if u become a train driver ill work out how to buy a train ticket and hitch a ride for like the first time in 7 years you better make some sweet ass annoucements for the lulz though
Or maybe either the blue or silver cars had had a previous accident and replaced their front bumper with a red one... like the crappy falcon parked near my work
Nah both car had their damaged bumper...
3way and the red car was already towed?
hit and run?
bumper fell off another car?
red bumper was in the rear cargo hold of a dc10 and the cargo door blew out (as was the style at the time) leaving the bumper to fall to earth?
red bumper thrown off overpass?
there was no red bumper?
red bumper was infact not in the book depository, but on the grassy knoll?
that gopher from caddyshack did it?
you are colourblind?
it was eps.
Didnt look like hit and run but could be...
No over pass around the scene
THERE WAS A RED BUMPER FOR SURE!!! i was not high while driving...well unless there was choof in my glass of milk this morning...LOL
And no not coloour blind...
That really puzzled me...lol..thought i share with you guys...lol
I think she can get away with it :O
+1...with her in the driver seat the car will look much better so the wheels are not going to get any attention...lol..therefore dont need any..lol...
Yep, no wheels is better :huh: Means she can't get away from us.
..I shotgun first go :O
Actually jks.. Her face has aids. All yours buddy :P
Edited by jezza boii
Yep, no wheels is better :P Means she can't get away from us.
Actually jks.. Her face has aids. All yours buddy ;)
Who cares about the face bro...paper bag job...dw about the face...f**k the base...lol... :huh:
got an adress?
bahaha :P
someone looks keen... :laugh:
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
