what about driving back home from the shops on Sunday at 4pm and copping a full epa :(
/sux to be in Knox council.
Times pulled over;
- Driving to Kmart on Sunday evening = defect
- Driving to Status Tuning after work on Wednesday = defect
- Driving back home from shops on Sunday afternoon = defect
- Driving back home from shops on Sunday afternoon = epa
- Looking for carpark on chapel street for dinner on Thursday evening = license check and on you go :domokun:
Majority of my defects/epas have occurred on Sunday afternoons. I dont like Sundays :down:
i know this isnt the right answer and my car is the same
but....................
you are driving an illegaly modified car.......................
thats a skyline........................
thats loud....................
twas very frustrating, just when you think its getting smoother and you start moving more than 10km/h....bang! you drive into a fkn hole
beater car sounds like a good idea
true. price of cars drop but cost of repairs/parts/maintenance dont. could go manual and save the headaches but i want the sequential
well thats cos the parts are still new my wing mirror cost 2k for one 1200 for the plastic shit and 800 for the heated glass stuff... headlight was 3k.. *shrug* car companies dont make profit on cars any more (apparently) they make it on the parts
my r32 is quiet compared to the trumpet exhausts around here haha
I had a cop who said that he believes its loud but wasnt sure loud enough for a defect. Told me to get it checked out just in case in my own time. Never did
f**k it, f**k it to hell
im bringing the r32 to the cruise
at least i can enjoy it and be paid out for driving an auto taxi in person for maybe the last time
also, full throttle, it spits out flames sometimes.. wdf
Wait till tomorrow night when your balls fall off and you choose not to go again.
Guest
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
