Why baby blue stokers tho?
One day couple of years ago he was bored and decided to spray it with some spray can we had laying around and that's it
replace the wheels with some decent non ugly ones and it'd look good....
what's wrong with it mechanically?
Yeah, was umm and ahhing about getting work meister for it.
Currently there's a leak from somewhere and it need retune badly.
Body would need a respray but couple of friends suggested cut n polish but I don't think it'll work.
While you're here, may I ask how long did you have yours?
And have you done anything exciting to it?
I bought my GTR back in August 2005.
Changed new front disks and brake pads.
Rebuilt Rear Diff.
Rebuilt Turbos to steel internals.
New OEM Clutch put in cuz the HKS Twin Plate just about had it.
Aftermarket Front Pipes and a Highflow Cat put in... Also have a Cat Back oval shape muffler going on.
New OEM Slave Cylinder.
Did more rebuilding rather then modifying.
I can dump money in it for the "Go Fast Mods" but I know 1 thing leads to another as this car cost already, as it is.
It is lightly modded and good enough for my weekend drives :)
I say you should enjoy what you got there (your R32 GTR) as you know, the power bug has hit you and you will never be satisfied...
First it is 200+ kWs, then you want 300+ kWs and you will be chasing 400+ kWs... It never ends... Leaving a bigger hole in your wallet.
Lower your standard of your expectation for your car and you will enjoy it better.
Remember, you do have decent mods on it... Utilise it and enjoy it...
That's what I think anyway :D
scar non?
Landed at hamilton island at 12 then had to evac at 4pm :(
Ho hum :(
go to the shooting range and hire a golf buggy and try get air in it haha
Was only there for a day passing through to the barrier reef. How long you there for?
yeah we are still on holidays , just not on hamilton island. Yep 4 hours , landed at 1230 and got ferry off at 4pm. We had time to try and get flights out (no chance) and time for a quick walk around a few drinks and lunch
Guest
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
