What do you guys consider the aesthetically classic cars that just don't seem to date & were way ahead of their time? I guess the criteria is the cars have to still look sexy no matter how long ago they came out. Ok I'll get the ball rolling:
1967 Shelby Mustang GT500
Mercedes Benz 300SL Gullwing
Mercedes Benz SL55 AMG
Lamborghini Countach
Lamborghini Gallardo
Ferrari 355
Ferrari Testarossa
Porsche 911 (duh!)
Nissan R34 GTR (no I'm not being biased here!)
McClaren F1
I know I've missed a heap here but I'll leave it up to you guys add to the list!
  • Replies 68
...or what about eyelids? >
http://en.wikipedia.org/wiki/Alfa_Romeo_Montreal
...or what about a sexier rear end/quarter than the Miura or Montreal? >
http://www.google.com.au/#hl=en&source...feeab1070eb158a
i wouldn't really put the r34 as being ahead of it's time since it was just updated 10 year old technology. and can't really say it has aged well as it is only 12 years old. and while i think the r32 gtr can be there for being ahead of it's time, to me it is starting to show it's age and lose its appeal.
also to add to the list, i would have to say the delorean, shleby cobra, ford GT40 and the model T ford
if you allow modifications then throw in a heap of old fords and chevs hotrods from the 20's and 30's. they are probably holding their looks better than what 90% of the current stuff is
Ferrari 308 GTB
R32 GTR
VK Group A Commodore
300 ZX
Supra RZ
VW Kombi van - Way ahead of its time ( As ugly and hippy as it may be )
Lotus Esprit turbo
Ferrari F40
Ferrari Testarossa
Porsche 911
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
