hey guys
vehicles in japan require a safety flare mounted generally in the passenger kick panel.
normally they are removed when the vehicle is being complianced, but they quite often slip through.
my NM35 doesnt have one and id really like one back in its holster.
so if you have a spare or one you dont want or need please let me know.
and id be happy to take it off your hands or buy it.
im pretty sure it wouldnt be able to be sent via post. so if you are in Melbourne preferably
cheers. :thumbsup:
https://www.sau.com.au/forums/topic/312042-got-a-spare-flare/
try ebay bud you can buy flares on the american site to suit all makes of imports... and they might even have a way to ship them i know you can ship dangerous goods as long as you declare what it is....... (mby a group buy to cut the cost of shipment) hope that helps.
my car didn't have one when I bought it but luckily we had the forethought to keep the one from the boys s13 when he sold it and it fits nicely in the holder :D
you should try other jap car forums like ns.com to see if someone with a silvia etc still has the flare. I don't reckon you'll have any luck getting one online sadly as you can't post them.
there's plenty of people on ebay selling just the tube for looks only - no flare included tho
Edited by Cheddar
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
