I've got I've got some 225/45 R18 Bridgestone Potenza RE040 on my AXIS wheels at the moment.
They are getting a bit worn, so I'm after some recommendations.
From reading some old threads it seems that I can either go for more 225/45 R18 tyres, or swap to 235/40 R18 which may give me more options.
I'm looking for something that's good in the wet, and ideally sub $300 a corner.
I've got no brand loyalty, so recommend away.
Thanks
https://www.sau.com.au/forums/topic/312401-tyre-recommendations-for-r18-axis/
225/45/18 and 235/40/18 will not give the same speedo reading.
With 235/40/18, the speedo will read around 3-4% higher than the 225/45/18
The 225/45/18 is a recommended replacement for the stock RS 17's as it does not upset the speedo.
I am running 235/45/18 on my RS and I can tell you that my speedo reads a little high.
Will be switching to the 225/45's as a correctly reading speedo is a nice thing to have and the extra 10mm over the 230/40 will fill out the guards nicely :P
I've got Toyo Proxes4 all round, 235/40/R18 fronts, 245/40/18 rears, probably best for their prices IMO.
I am running 245/40 18's on my AXIS. The rolling stock diameter of the tyres is within the suggested 3% variance. .its actually very close
I have the Proxes 4 tyres from Toyo and they are the best tyres I have has thus far. . $1,080 fitted for all 4, so $270 each.
The toyo's have a high load rating 97w . . which were one of the highest for that class of tyre. and needed for the 1.8 tonne wagon.
Will be switching to the 225/45's as a correctly reading speedo is a nice thing to have and the extra 10mm over the 230/40 will fill out the guards nicely :D
I have Khumo HR31's on mine, 245/45/18 on ARX wheels, this is quite a jump over std RS 17" rolling dia, but on a gps, my speedo is only out by about 3% as opposed to 9% :blush: with the std wheels and tyres.
The larger rolling diameter hasn't blunted the performance by much, but the ride is muuuuch better than before, even though the aspect ratio of the tyre is smaller and the extra rubber gives a much larger footprint. The extra width will still fit easily under the guards. They are also a nice quiet tyre with astounding amounts of wet weather grip. Also wearing quite nicely after 6000km.
Cheers, Dale
Cheers, Dale
interesting.... may have to break out the GPS and give it a little look-see
Bit of a boo boo in my original post. Khumo's are KU 31, not HR 31.
Cost $290 per tyre in 245/45/18 although should be cheaper now, as this size is std equipment on VE 18's and also current falcon 18's.
My speedo is way out already with the current setup. I think it reads about 10% fast vs my tomtom.
A smaller aspect should somewhat address that right? Smaller diameter should give more revolutions for equivalent distance travelled?
Thanks for the recommendations as well. Gives a more focused list to hunt prices on.
I *think* it should be the other way around - I went from the standard C34 Stagea wheels with 225/50R16s to 245/40R18s and my speedo is much more accurate now, despite the larger rolling diameter...
So I took the GPS to check how far out my speedo is on the way down to watching the "Classics" at Phillip Island yesterday.
Since I have upgraded my wheels and using the 235/40/18's that came with, my speedo is 10-11% out (reading higher than actually travelling).
Looks like a good excuse to get fatter tyres next time :(
  • 4 months later...
  • Could someone indicate which measurement must be within the 3% variance , in the quoted post?
  • Is the rim width on the M35 Axis Autech 7.5inch or larger ?
  • I need to know what tyre size will be acceptable when I go through compliance as I wont be around when it happens .
  • Has anyone tried the Toyo Teo plus for 235 40 18?
  • What new recommendations to Axis owners have for replacing the standard size 225 45 18 tyre or are you content with
    that size
  • What normal profile choice do I have if i don't proceed with a low profile tyre?
Thanks in advance
    that size
Thanks in advance
The 3% variance is for variation in tyre from O.E. I would guess.
The Axis rim is 18x8" +30 offset. It will easily take a 245 wide tyre without looking too "muffin top" :D .
As per my previous post; a 245/45/18 gives a slightly larger rolling diameter, and tested against a GPS, reduced speedo error from 110 km/h at a GPS verified 99 km/h, to 110 km/h at a GPS verified 107 km/h.
Khumo KU31 in the 245/45/18 has a load rating of 100.
Hope this helps, Dale
    that size
Thanks in advance
Hello,
It's the RSD Rolling Stock Diameter that needs to be within the 3% variance as it messes with the speedo.
Check here for all your requirements
http://www.1010tires.com/tiresizecalculator.asp
I swear by the Proxes 4, be sure what ever tyre you get has the appropriate load rating (eg 97w) as larger cars need a higher load rating, simply because they weigh more and is particularly important in heavy performance cars. I found many tyres had the right size but failed the load rating requirement.
I love the 245/40/18 97w profiles I have now and will not change. .
Remember the wider your tyre is, the side wall measurement changes in proportionate ratios. Which means a thinner tyre say 225/40 side wall will be a completely different size to a 245/40 side wall. It's all about relative ratio to tyre width.
Julius
Edited by Paramour
Hello,
Julius
Hello julius .
Thanks for the advice .
The japanese web site has 91 w for the stagea Axis autech http://www.autech.co.jp/HISTORY-SV/M35S01/eq.html if I decipher it correctly.
Where does your 97w come from as I cant locate any 225 45 18 tyres with a 97w rating
you in brissy mate
get your tyres from www.option1garage.com.au
very cheap
http://www.option1garage.com.au/NewTyres.htm
i think the ku31's were under $200 a corner
acutally, i found this, i asked for a quote a while ago
Kumho
235/40/18
KU31 $156.00
KU27 $192.00
KU37 $157.00
you in brissy mate
very cheap
Kumho
235/40/18
KU31 $156.00
KU27 $192.00
KU37 $157.00
Yes in Brissy mate.
Comments I have received seem to rate the falken 452just over the federal over the KU31.
Is that a fair commment.
I have usually run Potenza but just not economical at the prices they are sellinfg at .So now I am trading off safety a little bit for mileage .I was very disappointed with michellan Pilot precedes as they wore out real quick
Edited by samuri
send option1 an email and tell them what your looking for
they will recommend you a tyre and unless you can order from a wholesaler they will be cheaper that bob jane or other tyre places
they sell more than what they advertise, could be worth just going to see them
the ku36's are supposed to be a good semi-slick (beter than the federal rs-r's) but probably not what your after
don't really know much about any of the other tyres but i'll find out once i have some money for new wheels too
let us know how you go, where you went and how much it was tho
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
