I just realised... I thought you were going for 2 Bar SuperStar? Why only 24PSi now?
Oh and steve... My 880s on 98 are already hitting 70% dc from the calcs I did... And that was on 14psi only revving to 6500...
  • Replies 186
Well the exhaust is restrictive now so a bigger one is needed, the kw's were going up with more boost but not by much cause its choking so instead of stressing it out for every last kw, Yavuz made it safe enough to hammer everyday and turned the boost down.
Also, its pretty much quick enough for street duties as it is so why bother with more. Ive pretty much done what i set out to do on this motor, if i find a nice 4" exhaust thats another tune :banana:
Your fuel system just wont cope, ID's :D
No. I grew up on Oatley Bay and had friends round Connells Point and Kyle Bay. Haven't heard bout the N1 yet ,but Knowing my guys it will be pretty close to landing
Ah cool cool!
That's such an awesome buy, are you keeping it stock or going to town on it? It's a great base to work with :)
Steve... going by the injector sizes im assuming thats on E85?
You assumed correct.
Based on the boost it ended up on, it shouldve stayed pump98 but can be switched over at anytime (did tunes for both, just need to flash the ecu)
Steve, is that torque graph right? Looks to be 730nm...
Yep 730nm at wheels. Tractive effort was sky high, but that's not the number that matters.
Why doesn't it look right to you?
i was just questioning the number mate, nothing more :)
my previous gtr with 26bottom end & gtrs's made 750nm torque...my current 30bottom end with -10s makes 930nm.
our kw are almost identical but the nm is very different? maybe my ported made the difference?
would a similar engine setup with e85 @ 24psi (i.e. yours) v's 98 @ 24psi (i.e. mine) impact the peak torque? maybe its just a case that e85 truly works better on higher boost?
Marko do you have more graphs?
I'd like to overlay them and see what differences there are
the only graph i have is here: http://www.skylinesaustralia.com/forums/post-a235105-
i might have another 1 @ home, let me check later a/h
just to add, 405awkw = approx. 450rwkw (it was 1 of the 1st q's i asked my tuner when it was done on his dyno, my mates who drive fords & holdens always ask "whats kw is that rear wheels?")
Edited by Marko R1
I think the port job would be making some difference but the tune and turbos would play more of a large part.
It's not peak figures I'm looking at, i want to see what they're both making at every 500rpm point so yeah if you've got one and can send it that would be great.
How do you know it's 930nm without a graph though? A lot of people think the N on the side axis is torque, it's tractive effort not torque
jim (tuner) told me that the shown axis on my graph is in fact torque.
i'll see what else i have at home but come to think of it, im 99% sure the other 2 graphs are KW v's AFR & KW v's PSI
sorry steve, this thread is about your car & not mine :)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
