Ok looks like i will be upgrading from my twin setup to a twin scroll 6262.
Also have another mate/customer who is going the same but T3 single scroll on his 34 neo, and another we are fitting a 5558 on his built sr20 chasing big numbers.
I have heard rave reviews about these turbo's so i want to try one. Or three
  • 4 weeks later...
