anyone know of any GTR's running the PT6262 ball bearing with a T4 Divided .84 A/R with 3 5/8" V-Band discharge? would the .84 twin scroll be abit restrictive on the 26?
I have just bolted mine up today. The exact turbo u are talking about. Hoping to have it running by next weekend after i finish a 34 with PT5558.
I have fabbed up dump pipes for both and worked out cooler piping, plumb back pipes etc
This will be interesting Jez!
What's the specs for that 34?
Stock neo motor with Type B poncams and adj exh cam gear, link ecu with flex fuel tune, hybrid manifold, mvr 44mm gate, id2000's plazmaman ffp, DVS dump and plumbback pipe. Hoping to have it running and tuned early next week. Depending if Link arrives and also waiting on plazmaman plenum to be finished.
I was wondering whether you got the new turbo in yet, guess I have the answer.
How much boost are you going to run do you think?
That i will have to see what the engine likes when im tuning it. I will see how confident i feel with the power output as its a stock motor. Also running stock cams atm. I would like to see the differences in stock cams then type B poncams. Then i will think about doing variable cam once i have to upgrade the headgasket.
Very nice, shame its a stock motor as its probably not going to be able to show its real strength. I am assuming its a ball bearing 6262, and you are going to tune for E85?
Yes both are ball bearing. My rb26 i am trying to get as much response as possible which is why i went twinscroll 6boost manifold and .8 twin scroll rear. My old steelwheeled highflows came on hard around 4500rpm ad made 307 so i am aiming to better that
Yes both will be tuned on E85. They are actually both going to be be flex fuel tuned.
We understand the stock motors will be the limiting factor but not going to build the motorS until the time comes
Nice, very interested to see where it comes in - I've always had it in my head the PT6262 would be on the laggy side, though never been sure. If it can be all in before 4500rpm then that'd be fantastic :)
Are you going to stick with 2.5" out of the IC into the plenum or go 3"?
3 inch is pretty big Roy, I usually use 3 inch out of the turbo on builds over 400kw, I know it supports at least 550wkw from a car I did recently... 2.5 inch should be fine mate for either side.
I also fabricated piping for a built STI Liberty in 2 1/4 alloy, it runs 280awkw. More important is the cooler end tank design imo.
Just curious, mine are 2.5" and the numbers suggest that for 590cfm it should be fine with 2.5", but as always its interesting that the RB26 and GTR run 3" std
I see what u mean Roy, we will find out soon but i dont think the 2.5 will limit the setup. I think the only thing that will limit the setup is the standard internals
the engine will take allot of abuse with that turbo on e85.... :P just dont be scared. These turbos come alive at around 28-35psi.
Stre180 sr20vet made 'apparently' 760rwhp on a 6262 .63 housing it would want to be a low mileage 26 to even make 600whp reliable.
I agree it would want to be a "known" engine but really 600whp is a walk in the park especially for a few dyno runs....if it was my own personal car like it is with jez i would have no problem running it regulary at 400rwkw. We see this power quite often on std 26 engines on E85. I reckon in realistic power @ 35 odd psi 700whp is achievable with that setup but i would stay sub 30 on std bottom end.... i still find it difficult to believe that 760whp result with the 0.63 housing.
Interesting that you mention that, someone I know hit 400awkw on E85 at around 22psi with his unopened <100,000km old RB26 and coolant started escaping places it wouldn't, I had thought it should be reasonably safely doable too... good to know there are plenty of others which have done so fine.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
