Left it for now. Was up too 262kw at 5500rpm 14.5psi. Was just having a play tonight and good to hear it running.
Waiting on the new fuel system to arrive so we're ready for the eflex.
Surge tank and lines are on the way after ur very helpful input Matt. Cheers for letting us know about urs.
Fark im so keen to get mine on the dyno now.
Looks very similar to GT2871 results on a neo 25, I have a turbo that is highflowed with the same wheels that looks very similar to that graph though less power due to the restrictive rear housing.
http://imageshack.us/f/4/img20120517221202.jpg/
Be interesting to see how well this turbo performs when you finish the tune! Neos always seem to give fantastic results.
http://imageshack.us...0517221202.jpg/
Yeah.... Nah! It doesn't haha
Neo usually make a little less power actually because they are pingers
The few tuners I talked to seemed to think they always made more power as they seem to rev more, seen two results that seem to point that way, eg matt from nistunes r34 that makes 310rwkw on a 0.63 gt3071r with poncams on only 18psi, dyno sheet is on here from a reputable dyno/tuner, and then mine which is a highflowed rb20 turbo with the rb20 rear housing still that makes ~258kw on only 16psi
Edited by Rolls
On the same dyno for both?
Regardless from what i have seen, neo's seem to get a bit more compared to regular rb25det's with similar bolt ons.
Yep both on same dyno same tuner. Pete from nistune and the morpowa dyno in adelaide, he told me every neo he has done has gotten fantastic results compared to the r33 engine, "chalk and cheese" were his words from tuning multiple neo and r33 motors.
I also had identical everything just changed from r33 rb25det to a neo rb25det with the r33 intake, all the same sensors, hoses, literally everything the same just the block changed and went from ~236kw at 18psi to 258kw at 16psi.
Edited by Rolls
That's a solid improvement!
Is there any rewiring for sensors or the loom etc needed to put a neo rb25 in instead of an s2 33 rb25 or does just the ecu need to be changed?
The 34 looks like it will put up a good number, I think you'll shite 400kws in Jez
Im curious to see when this turbo maxes out.
I know Kurtis is now a power junkie but this thing is aimed at max response with strong top end. I have the goal set at 350+.
Time will tell with my one too. Its a 700hp turbo. But same again its main goal was response and 380+
He'll make it, i have faith! Its a 700hp turbo vs my 550hp turbo and i NEARLY made it, so you guys will make it for sure :D Cant wait to see, its sounding good!!!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
