lotsa boost is nice
you have really put these back on the map for me.
i need to consider if the loss of response over the 20g (if even notable) is worth the future potential.
i could potentially have a very badass setup ready for E85 ONCE the shit becomes available
Im curious to see when this turbo maxes out.
I know Kurtis is now a power junkie but this thing is aimed at max response with strong top end. I have the goal set at 350+.
Time will tell with my one too. Its a 700hp turbo. But same again its main goal was response and 380+
Come to be fair I'm a junkie now because my friend had to go get him self a dyno : )
I have a figure in mind may be dreaming but all I know is just with his little play last night Jez has got it with in 10 rwkw of my hypergear power
So this turbo is what I should have got the first time around.
More then happy already
You will get your goal man, its already performing awesome! Cant wait!
That would be making a pretty big difference. Be interested to see what the G3 can do on a proper ext gated setup or the 5556 int gated on stockie setup.
We are not judging the old setup but its good to know the new setup is worth the money
As said nothing against the old setup but here is the overlay from the first few runs.
Alot has changed, high mount, external gate, plazmaman FFP Link ecu etc.
Sorry about the typo its an atrg3 not ss2
In my last post I did not mean to miss lead anyone relating to setup.
A lot of changes have been made , but I was more referring to The way new setup Is performing.
You'd expect a better result purely based on the $$$ factor in the new setup compared with the old.
Is there bigger cams in the 34 or any head work?
Stock unopened neo motor. Except i fitted type B poncams to it last month with the old turbo.
Perfect combo ;)
Scary tho. The 040 pump thats in atm was losing flow at 12psi. So glad we ordered the surge tank etc. looks pretty.
Will start fitting it up tomorrow. Not sure how im gonna join to the stock connectors but
Will have pics etc as soon as I can man... Was hoping today but the video of the tune got me distracted :P remind me in the morning and I'll get it sorted ;)
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
