We have a GTR over here that runs on full 100% ethanol. Makes 630rwhp on a roller, gets the pure ethanol very cheap through a limited source.
Almost wouldn't start after sitting at the track on a cold night so not really a great recommendation haha
E100 isn't new, been there done that :)
An R34 with those K's though, never seen one in real life with that many k's on it!
You still haven't, it was a picture :ph34r: hehe
Its a good sign for the other 34's on the road though, shows they are well built!
Kurtis, the suspense is killing me already!
Oh come come now. You Daniels 34, tuned by Status - makes over 400 on E85 with just a Nismo :)
Exactly my point. 044 around 200lph. Nismo 246lph but i cant find specs for flow at higher psi which is where it counts
Well for a while I've suspected the Nismo pump to not be "as much" of an upgrade over a stock GT-R pump as many would believe.
It's simply the cheaper option so hence everyone goes down that road given a stocker is 10yrs old and offensively priced from Nissan
There are some numbers on a stock GT-R pump below (makes for some interesting reading).
http://www.stealth316.com/2-fuelpumpguide.htm
working in the boot of his car paid off today, AFR's are doing exactly what i wanted tonight. Just got back from a drive with it. went down to the servo to top up the $21 worth of EFLEX, racked up some sensible km's, think we are up to 50km just cruising around with a few squirts on 14psi low boost, and only 1 half throttle tyre fryer on high boost, got scared as midnight and tired, had a big day.
Maxed out at 367kw on 22psi, tried more boost with no gain, but very impressed as its all legal in the way of Catalytic converter and wastegate plumbed in, thing is a sleeper.
still got to finish the tune back from E67 down to 98 octane but atleast everything held together :D
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
