A little? lol... A LOT!
I just wish I new where to start, it's got everything it needs to make a decent number, but it's knock restricted.
When jez tuned it last the exhuast was way to small, now that I've got a bigger system coming from jap and I made some 3inch tuned length front pipes into a 4inch merge. The exhuast issues should b over, so it's back to jezza's shop to c if there's any gains.
Strange thing is, I had a 4inch system made, and we chucked it on the dyno, only got 7kw gain with adding timing and boost.
C what happens, maybe we need to play with the cams, or something.
Depends what manifold you get.. The Full race one I have was designed for fitment on 33/34s. Tried putting it on my 32 and the compressor fouled on it..apparently full race have rectified this for 32s now
A/C didn't work anyway so I'm not too fussed, then again I may have wanted to fix it one day :s
I saw a dyno graph from a famous 32 on the weekend. It's now running a Precision single (6766 I think he said). The Precision shits allover the -5's for response on the graph, and from his times, on the track too! The 32 is still 2.6 as well so these turbos are obviously a good thing!
Correct! and yes WOW! it has me thinking the EFR's are on their last chance... :yes:
I've already emailed him to find out exactly what version he has on the 32.
The 34 is running one also, however he likes the one on the 32 better.
One thing he did say to me was to buy bigger than I think I'll need and I won't be disappointed, they are that good.
I would choose a Precision over an EFR any day. . .too much hype with the BW's. . .too many results to look away from Precision. . .sorry, but a 2-year wait on an EFR is ridiculous. . .
bri73y.. .do you have a chart for that r32 running the 6766? I'm running this on my FD. . .sounds too good to be true that it would shit on the -5's. . .
No sorry, it's not my car, although it has lived in my garage for a while previously. Damn should've stolen bits off it when I had a chance.... :whistling:
Any email back? The one on the 34 did look a little bigger but by how much I couldn't say. I'd love to know!
What do you think you will order for your car John? 6466?
Hey Joe, or anyone for that matter..
Is there any evidence that the Full Race Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a good manifold and probably a Precision..
wouldn't the one Jez is running, with 30+ psi on a 2.8L with cams etc see 450-500rwkw ? with awesome responce .
Edited by tricstar
Is there any evidence that the Full Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a 6boost and unplumbing the gate.
Fixed, no need for new turbo :)
Well it made 436 on a 2.3 SR with 24-25 lbs of boost on the same dyno as i made 425 with -5's. It beat my setup low end and pipped me up top. I'd love to see what it would make with 30 psi!
If the 6466 is too big just rip it off and drop back 1 size. Little touch up and away we go!
Honestly mate don't know if the full race is better or not. Would need to do some back to back testing which would be a real pain in the ass as you would need to plumb up 2 different sets of gates.
If I had my time again I would probably just bought a 6 boost one for reasons such as
1. Cheaper
2. Quicker to obtain (each fullrace manifold is made On order)
3. If it cracked or failed in anyway would be easier for warranty
4. The full race is a bit of a nightmare plumbing wise.
Though I do like how the manifold looks and how it makes the turbo sit towards the front of the car.
I also had to cut a bit of the re enforcement out of my bonnet to fit the Massive frame of the BW
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
