A little? lol... A LOT!
I just wish I new where to start, it's got everything it needs to make a decent number, but it's knock restricted.
When jez tuned it last the exhuast was way to small, now that I've got a bigger system coming from jap and I made some 3inch tuned length front pipes into a 4inch merge. The exhuast issues should b over, so it's back to jezza's shop to c if there's any gains.
Strange thing is, I had a 4inch system made, and we chucked it on the dyno, only got 7kw gain with adding timing and boost.
C what happens, maybe we need to play with the cams, or something.
Depends what manifold you get.. The Full race one I have was designed for fitment on 33/34s. Tried putting it on my 32 and the compressor fouled on it..apparently full race have rectified this for 32s now
A/C didn't work anyway so I'm not too fussed, then again I may have wanted to fix it one day :s
I saw a dyno graph from a famous 32 on the weekend. It's now running a Precision single (6766 I think he said). The Precision shits allover the -5's for response on the graph, and from his times, on the track too! The 32 is still 2.6 as well so these turbos are obviously a good thing!
Correct! and yes WOW! it has me thinking the EFR's are on their last chance... :yes:
I've already emailed him to find out exactly what version he has on the 32.
The 34 is running one also, however he likes the one on the 32 better.
One thing he did say to me was to buy bigger than I think I'll need and I won't be disappointed, they are that good.
I would choose a Precision over an EFR any day. . .too much hype with the BW's. . .too many results to look away from Precision. . .sorry, but a 2-year wait on an EFR is ridiculous. . .
bri73y.. .do you have a chart for that r32 running the 6766? I'm running this on my FD. . .sounds too good to be true that it would shit on the -5's. . .
No sorry, it's not my car, although it has lived in my garage for a while previously. Damn should've stolen bits off it when I had a chance.... :whistling:
Any email back? The one on the 34 did look a little bigger but by how much I couldn't say. I'd love to know!
What do you think you will order for your car John? 6466?
Hey Joe, or anyone for that matter..
Is there any evidence that the Full Race Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a good manifold and probably a Precision..
wouldn't the one Jez is running, with 30+ psi on a 2.8L with cams etc see 450-500rwkw ? with awesome responce .
Edited by tricstar
Is there any evidence that the Full Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a 6boost and unplumbing the gate.
Fixed, no need for new turbo :)
Well it made 436 on a 2.3 SR with 24-25 lbs of boost on the same dyno as i made 425 with -5's. It beat my setup low end and pipped me up top. I'd love to see what it would make with 30 psi!
If the 6466 is too big just rip it off and drop back 1 size. Little touch up and away we go!
Honestly mate don't know if the full race is better or not. Would need to do some back to back testing which would be a real pain in the ass as you would need to plumb up 2 different sets of gates.
If I had my time again I would probably just bought a 6 boost one for reasons such as
1. Cheaper
2. Quicker to obtain (each fullrace manifold is made On order)
3. If it cracked or failed in anyway would be easier for warranty
4. The full race is a bit of a nightmare plumbing wise.
Though I do like how the manifold looks and how it makes the turbo sit towards the front of the car.
I also had to cut a bit of the re enforcement out of my bonnet to fit the Massive frame of the BW
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
