Ok 5558 on built sr20 is now run in. Boost was uncontrollable due to a mixture of incorrect wastegate spring and a loose block off bung in the side of wastegate.
Went for a quick roadtest to check boost pressure with 8psi spring and its running 14psi. With a 4th gear foot flat 2500rpm pull was cracking gate at 3500-3700 (14psi)
Will tune as soon as i get some time
Ordering from the US is always better for service IMHO.
I used Real Street Performance on a few occasions and delivery was about a week on all orders. There was one odd time when they couldn't ship an item because it was missing a piece from the MFG (the value of non drop ship vendors). That was rectified fairly quickly by the vendor, the supplier was a little slow though and I ended up taking a payout instead. Item arrived at my door, missing the said gasket, within days of telling them to send as is.
They also sell PT's and pricing is as competitive as it gets.
6466 is now on the manifold, and i am now looking forward to cutting myself to bits doing the pipework lol! Also, just an FYI for you simon, you may have trouble with the outlet on the turbo if mounted on the greddy manifold as mine sits rearward moreso than the greddy items, so pipework may have to face directly downwards and do a 140 degree turn.
Pics would be handy :)
Pics of super snail!!!!
Sort your line out?
just waiting on a 12mm metric to -3 adaptor and i will have the oil lines sorted. The pressure pipework is going to be the next interesting part. The thing looks small compared to the 78-33d. It only just fits between the cam covers and the strut tower lol
Hey you guys with precision v-bands, re- the 3" outlet to dump pipe, -the v-band flange welded to the turbo doesnt have a seat for the female flange and the Performance Exhaust at Northmead guy told me I need to get a female flange milled to suit with the clamp and my turbine flange because most of the time the clamps are too wide and the dump has play in the joint . He said it will fit first time but not after if I just get an off the shelf vband flange kit. Is that correct and what you guys doing about that? Where and what size T3 spacers you using, theres some 11mm ones on ebay, mine is a 5558 to go on stock rb25 mani- low mount.
Last question- oil feed and return, any suggestions on fitting sizes and line lengths? Or just let the tuner (unigroup/jem etc) sort that out..
And how much u guys paying for fabrication work, and any recommendations? Pm me if you dont wana post on here, thanks :)
Edited by rondofj
I can preeeety safely say, if its unigroup, let them sort the oil line for you. The 6466 i have was supplied with a machined V-Band flange, looks the goods and mates up 100% primo. I suggest talking to the unigroup guys and leaving it in thier capable hands mate :)
Thanks man, ur lucky you got a flange n clamp supplied as the precision ones are different in size to regular vband flanges and dont seal properly according to the exhaust guy and on the web, can anyone else with this 5558 or other 0.63 vband turbo please tell me where they got their dump flange n clamp from?? And any pics of how the gates welded to the turbine? Thinking if i should point the gate sideways towards the firewall or up upwards like a hat. Turbo will be Low mount on stock rb25 mani
Edited by rondofj
Don't be stupid Paul, there are no compressor maps so they are rubbish.
Lol, not what I said... they are your words. But continue to misquote me to the benefit of being an internet hero.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
