Being built by advanced and tuned by JEM I doubt anyone will question the numbers.
Interesting about the breather being normal for that power level, not something I expected.
Because u dont normally see it.
Out of site out of mind :)
It's the catch can breather.
For anyone possibly doubting the numbers, it ran 10.7@147mph at WSID with 490rwk. Next time out with 536rwk should do 150mph+
The car is also on the Motive 16 Drag battle DVD.
I'm questioning the numbers! That was 10.2@147 not 10.7! :)
This was the first thing I noticed as well
Seems odd to keep pulling those numbers with that happening
It was mainly in relation to that...
Yeah I wasn't sure if it was 10.7 or 10.2 :D
Edited by SRS13
I might be selling my 5858 BB turbo. Brand new, box hasn't even been opened!! After $1450 for it.
Thinking about going bigger (6262) as the engine being built will need a bigger turbo!
If interested PM me.
Edited by SRS13
Finally got some numbers but its not done yet,
On the New motor, with the 6262 .84 TS BB CEA.
Run-in tune (super safe) verylow/negative timing, 9-10 psi. 210-220 rwkw.
Turbo is super responsive and perky even with the timing so low, I noticed instantly its very throttle responsive, its very possible my intake setup helps in this regard. But the way it moves the air so quickly I have a good feeling this setup will be pretty decent on the 30/25 with vct!
One noticable characteristic.. the turbo seems very loud. even on low boost. however i am moving from lowmount to high mount during this build, so that might be why i think that.
will be doing real tuning next week if all continues well. Will post numbers as promised when its done. Unfortunently still running hte PFC and Tomei Z32 as no one has purchased the gear yet.
-dale
Edited by SilverECR33
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
