As has been said many times before, if you drive sedately like a normal vehicle for the last 1km or so there's no need to let the car idle when you're parked. Just don't thrash the thing before pulling up at your destination and you'll be fine.
okay im looking at getting a 6262 .82a/r Twin scroll with a matching 6boost manifold. Can anyone tell me about their experience with this setup i have not found any results with this turbo on a RB25. Im after getting about 500hp but need some headroom for further plans. iVe noticed a gtr doing this at about 20-24 P.S.I but rb26 and rb25 are a bit different. Any help will be appreciated.
http://www.skylinesaustralia.com/forums/topic/377634-gt35r-or-precision-6265-ballbearing/page__st__20
First post on the page, that guy says good things about it. Maybe PM him to see the housing size?
Thanks bro that's a Gtr though.I've noticed that not a lot of RB25 go with the 6262.what makes it harder is finding one with the twin scroll as I want to find out how much laggy it would be.
Bryce, I know from experience that the 6262 and GT35 are very, very similar in response. There is a back to back comparison from the US here: http://forums.nicoclub.com/highest-horsepower-rb25-stateside-t477938-40.html
Note the 6262 was running a larger housing (Tial) I don't the Tial v-band housings do anything extraordinary at all...
Also, PTE make a .84 T4 divided housing only.
Cheers,
PJ
Bryce, I know from experience that the 6262 and GT35 are very, very similar in response. There is a back to back comparison from the US here: http://forums.nicocl...t477938-40.html
Cheers,
PJ
yh i meant .84
might get the twin wastegate setup if the funds permit but if not will stick to a single W/G
so im set on a 6262 TS .84 aiming for 550hp and some headroom
Took my car for a quick spin today, was getting 1 bar in 3rd at about 4000rpm and just below 4000rpm in 4th.
That was running gate pressure of around 1bar (so not exactly optimal as it would be opening partially before then) and has not been tuned or cam gears played with yet! Pulls fairly well for only 15psi :)
That's a 6262 on a stock RB26 with drop in cams.
So far so good, can't wait to get some results from the dyno
Edited by SimonR32
Scott is right. T4 0.84 divided
I'll check at 3000rpm if I get a chance, it seemed to be ramping fairly quickly at 3500rpm
Whats the rest of the setup? rb26 yeah?
What piping and throttle body are you using? that would make a diff to if its short rb26 plenum runners.
Hey guys, see pics of my PTE 5558 0.63 plumbed up to my R34, injectors and tune coming this Monday, 98 fuel and as high boost as possible. I urged them for a safe 22psi but JEM says they mostly go 20psi on 98 fuel unless its a built engine?
Words of their salesman so I'm sure the tuner will give a slightly different perspective. Well fingers crossed and really hoping to crack 300rwkw - its on stock manifold btw.
Do you guys see issues with the way the pipes run (I think the 3" from pod is a funny angle), the weld quality looks top notch.. ;)
Edited by rondofj
looks good ronny!, be good to see how it goes, My big Pt cleared customs friday..bastards tried to stitch
me up...lol, ended up only paying gst on $1000 and payment for submitting form, so $178 extra...was $600 ish
intially as they tried to to tax me on $2500
cheers
darren
Edited by jet_r31
cheers
darren
which one did you get mate? I paid $1050 all up for turbo, 2X silicon joiners for turbo cold side with clamps and incl postage too. I didnt pay any duty haha
.., nah i paid it, because it got sent from a friends house in ohio, and she sent it without asking
and instead of writing nothing about it, the goose put turbo worth $2500 on the postage..customs picked it up straight away
I sent a letter explaining it was a second hand journal bearing 7675 ..that i only paid $1050 dollars for it..lol, and that i can buy them of ebay for $1500 delivered from the u.s
any day of the week, so why would i pay $2500, so they just charged me GSt on $1050..i was happy with that.
cheers
darren
cheers
darren
Lol @goose hahaha cracked me up..I got the seller to put 850 on the sticker so paid nothing in tax
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
