Made 286rwkw from 5558 on stock mani low mounted 98 fuel, boost 18psi dropping to 16. Told tuner to push it to 20-22psi but intake temps getting too hot. He said forward facing plenum will help cos it doesnt run along radiator and over exhaust cams as stock piping layout.. Its cold beside battery tray but heats up the next few centimeters.. Oh man that damn 300rwkw
water injection mate...wel done anyways.
cheers
darren
Good work Ron!
How does it feel on the road? Does it compare to the 335kw machine you went in?
Also, who tuned it? JEM?
First impressions- L-A-G----- boy its as doughy as f**k, maybe at 60% of the stockers response up till 3500rpm, after that its coming coming then 4000rpms WHOA BANG it fkn grenades like a rocket, not much difference in seat of pants feel to the 336rwkw car, feels almost, say 90% as mad when boost is on its on! Skates and wheelspins a bit but not too mad, its awesome but the lag is just way too much, I havent driven a ' proper turboed' car so cannot judge, when I come back frm my overseas trip on Jan, u can drive it and gauge Jase, love it but the lag sucks, theres no power below 3200rpms... Is this how its suppposed to be?? 2990rpms=60kw, 3790rpms=120kw, 4720=225, 5470=260kw, 6660rpms=286rwkw
Good work Ron!
Cant upload dyno graph from iphone in the dyno results thread damn.. Anyways fullboost 18psi around 4000rpms and drops to 16psi from 5700rpms, JEM are awesome, ADAMs a top guy definitely recommend him really goes out of his way to help and explain, takes his time to go through detail by detail :)
sounds a little bit laggier than my old GTST with a 3071R on it... mine was tuned at 20 psi... see attached dyno
the different is the PT will have a lot more in it! chuck it on e85 :P
I wonder how that would compare to a standard G3 type B... For on road feel anyway.
Get the sheet up when you can, I would love to see it.
Hi guys,
I've been following this thread with quite a bit of interest and thought I'd share some info on my project.
I running an FJ20det which I swapped from my old DR30 skyline into my 1600. The previous turbo setup used a Fantasy split pulse single waste gate manifold and a twin scroll GT3071r and made 265rwkw on 22psi.
I have since built my own twin scroll manifold with twin waste gates for the 3071r. I have also built a manifold for a Vband in and out Precision 5558 which a friend of mine sources from PJs Quick Bits. I will be doing a back to back test of both these turbos on my FJ in the next few weeks and will post the results.
Cheers
Awesome that will be interesting, what fuel and engine spec? That Precision turbo should have a big edge on potential for power advantage but may need to be pushed harder than 22psi to prove it's extra lag is worth it
The engine has been rebuilt with forged piston and port work to the cylinder head. Cams are still standard. I will definitely run som proper boost through the 5558 as that's what they are made for!
I currently run two maps and I will have both tuned for each turbo set up. One for pump 98 and the other for pump 98+water injection provided by an aquamist HFS3 system. Made 295 rwkw @ 28 psi using pump 98+water injection with the 3071r. This is compared to 304 rwkw using c16. I can't speak highly enough of the water injection and once you have set up and tuned it, it's cheap as chips to run. 30 rwkw when ever you want for under a grand fitted and tuned! Can't argue with those results!
I dont think it is.
that's not why I questioned it lol, look at the power he made. 295kw. Given that he also said water injection = free 30kw, a 3071R would make 265rwkw on 18psi without hassle. Not 28psi lol.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
