Why have I been thinking you both had the .82 v band rear?
I think it's partly because of the numbers you put out I must of just assumed...
So what is the go with a .63 5558 compared to a 3076r in terms of compressor and turbine wheels then? Because it seems to put out very similar numbers to a .82 3076r
Well 280-290kw with full boost at 4000rpm isn't too shabby for a JB turbo, though no better than a Kando T67 in spool and a bit concerning if IATs are getting unacceptable. Sounds to me like the Kando would be a better unit for this kind of setup, though the ball bearing unit would no doubt be quite a bit nicer.
True, I don't think anyone is punting a T67 on the stock manifold. The comp housing is too large from what I know.
I have to say though the result from Kurtis is really nice. Spool is mega and so is power, but it needs to be said hes on a high mount and E85. The T67 is probably better off at the level Ron is at (with a cheap highmount) but the 5558 would be better in terms of contingency.
Not to rub anything in to anyone, but we all did say 'buy a hypergear' about a million times lol.
What do you mean by contigency, JD?
Contingency planning in case Ron gets bored of his current power I mean. The 5558 seems better matched to the highmount and E85 slurping setup that he would probably move to from there, based on the result from Kurtis which seemed to be very responsive whilst making its 360kw.
Kurtis car has a very linear power curve on the street, when he took me for a run in it, even on high boost it would hardly brake traction.
It came on very low in the rev range, and pulled smoothly all the way to redline. Not like a laggy single setup or twin setup which has the nothing nothing nothing and than bam it ramps on hard wheel spins all over the road, than bogs down when u kick it up the next gear.
Long story dude...had a friend of a friend mini tub it..car went missing and shit stolen and paint f**ked(it was a new paintjob already)
I had all the dodgyness fixed/ retubbed/ 4link/cage fitted and my mate that painted it the first time...has fixed and repainted it for FREE...(instead of another 5G), so i can't complain..
Not like i havn't seen it..lol, my mate lives on a farm and has his workshop and booth there..haha
..Turbos a Gt45 frame , its a discontinued turbo..you havn't been able to get them for 3-4yrs..hence me taking 2 yrs to find one in the U.S. checking google every week..was a headf**k to buy and get here
Edited by jet_r31
Boost leak has been fixed since then Deano, the bov he installed was poo. Was leaking at 1 psi with the smoke test.
But yes its a nice linear power curve not a lag monster
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
